John25mm
Just remember when pushing over a dead tree, that the top may snap and fall on you. I just heard of a friend of a friend that was doing this with a small dozer and the top snapped off and came down on him. He is now a paraplegic. I have resorted to cutting dead trees off about chest high, which leaves plenty of height on the stump to get good leverage with the blade when removing it.
Be safe out there.
Good point on the 'widow makers', they are called that for a reason. I have had a couple come bouncing down on the ROPS I have. I have the real one and not the sunshade version. It makes a lovely gong noise. The other fun thing to watch out for is if you are pushing a bunch of blow/push down trees be very careful about things coming into the cab with you. I had a tree limb/spear come right over the top of the engine and damn near pin me to the seat like a bug. Trust me when I say it doesn't take long for something like this to happen even at the slow speed of these dozers.
One of the other things you can do to get larger stuff is first is like I said cut the push side roots then as RRRancher pointed out to cut the stuff around the other sides but push that dirt to the push side to make a ramp of sorts. this will allow you to get a little higher up and apply a bit more leverage to it.
As a last resort(because I am a bit lazy). If you can climb the tree a bit hook a chain or cable to it and pull it over. I got about 300ft of 5/8" cable from a crane company for free. The only thing I had to do was sign a letter saying I would not use it for lifting and that I understood that it was being taken out of service due to age. Not a bad deal when I am using it to pull trees off of hillsides. I have cut it into two sections of 100 and 200ft that I can hook together if I have to. It is a heck of a lot easier to pull that cable up to a tree either by hand or with a four wheeler than to get the dozer up there. and as a plus I now don't tear up the ground as much with the dozer.
