I have given this some thought, crawlake, and I surely don't know the exact answer to your problem, but this is what I'm thinking. As far as I can tell from reading the service manual, I don't see any actual adjustments for the steering clutches themselves. The clutch is normally engaged by the springs inside of it pushing the plates and discs together. It is disengaged by actuating the release yoke. The release yoke is actuated by the steering booster cylinder, which is supplied oil under pressure from the steering control valve when the steering lever is pulled back, pushing the plunger in on the steering control valve assembly.
So what I'm wondering is, is it possible that your steering lever linkage is partially pushing in that plunger, even when it is fully forward? I really don't think that is what is happening, but it could, I suppose. If it is not that, I'm wondering if there is something wrong in your steering control valve assembly that is causing it to always be supplying a little oil pressure to the steering booster cylinder, which is almost disengaging the clutch. Not enough to disengage it during normal operation, but enough to disengage it when you are driving against an immovable object.
From what I read, when the steering lever is pulled back partially, there is a modulating action taking place within the steering control assembly, which partially releases the clutch. When pulled back all the way, the modulation ceases and there is complete release of the clutch. If there is a problem in your steering control valve assembly, perhaps it is always in a modulating mode and the clutch is never fully engaged. If you have the service manual, pages 21-63 and 21-64 explain this in detail. I have not been inside my steering control valve assembly, and I have no idea how hard it would be to open it and inspect the inside for something like a bad o-ring, broken spring, or stuck spool, etc. I think that would be the last thing I would do, and only if I couldn't find anything else.
All of what I'm thinking here is assuming the steering clutches are assembled properly and function as they should when the release yoke is not engaged. You said you replaced the clutches, so you should have a pretty good feeling about that part. If they are working properly, I just tend to think that the release yoke has to be partially engaged enough to partially release the clutch plates when pushing against an immovable object, but not enough to release them under normal loading. I may very well be totally wrong about this, and I will defer to any expert who knows more about this. Hopefully this may help you troubleshoot and find the problem. Best of luck with it.
