twisted235
Anyone found a starter that will work on a d21s that is less than 500.00?I was thinking about a yanmar starter or an isuzu starter or possibly a fiat allis starter.
Have you tried to rebuild the one you have? Or have someone rebuild it?Anyone found a starter that will work on a d21s that is less than 500.00?I was thinking about a yanmar starter or an isuzu starter or possibly a fiat allis starter.
has anyone seen or know how to put an deacceleration pedal on a D21?Oh yes they tell me they can't get the parts for it.I am going to visit Darinray and see if he has the parts I need. But most likely I will just go ahead and spend the money for a starter. I found 1 for 400.00 so I will only have around 4000.00 in the machine. It seems ok other than the starter.
James, I have a 50 acre tree farm that is overgrown with sweet gum trees interspersed in the pines and oaks. I use my D20A-6 to root these out and leave the oaks and pines more room. I just took a picture last week of a typical looking area that will be worked on soon. The D20 will run right through the sweet gums in this picture, but if I had to take out the larger pine in the left side background (looks like about 5 or 6 inches in diameter), I would likely have to angle the blade and take out some roots around the base of it first before pushing it over. I have found that you can start pushing against the base and then raise the blade, which does a pretty good job of plucking the tree out of the ground enough for it to fall on over.I was wondering if anyone has some phot's of the type of brush, bushes and trees that one could realistically deal with without overworking the machine. I thought about getting one of these.
But, thought I might need to go to the D31. I've got a lot of underbrush (vines, deadlimbs) and such that I want to push into small piles and burn. So, I was hoping to see what size of tree one could push without abusing the machine.
