Getting the brakes to work shouldn't be that hard. They are exactly the same as air brakes on a truck. You need to set them up. 9/16" wrench, set them up tight, back off ¼ turn. Only problem is you need the park brake released to do it. Hopefully the brake chamber pancakes are not blown out. Easy enough to check. If the brakes release with the button, and you don't hear air blasting out underneath, the emergency side is good. Then, if you can press on the pedals and not hear air leaking all over, the service side should be ok. Be aware that if you hear air leaking underneath during either or these tests, the chambers could still be ok and the quick release valves could be faulty. Good luck.
