Tinkerer
Please get the brakes working before someone gets injured or killed. Roll the backhoe bucket all the way out and drop the boom to stop and or hold the machine from moving.
That thing is not going anywhere til the brakes are fixed, for sure.Please get the brakes working before someone gets injured or killed. Roll the backhoe bucket all the way out and drop the boom to stop and or hold the machine from moving.
I dunno Overtorqued. Only if the metal arm on the pedals is in position to operate both pedals at the same time. Swing it over to enable individual brake operation and see if one or both pedals are functioning. Does the system have air pressure built up ??Hi all, back at it again. Happy 2016! Took a look at the brakes today and it seems one of the valves on the brake pedals is frozen. Must be the problem i would imagine...
Individual operation, only one side depressed. Pulled the whole valve unit out and it was in two pieces! Case was busted and the one valve was definitely frozen in the bore. That part is of course obsolete but I think I located one on eBay to the tune of 400 some bucks! These old tractors really bend ya over on the parts, but it's still worth it.I dunno Overtorqued. Only if the metal arm on the pedals is in position to operate both pedals at the same time. Swing it over to enable individual brake operation and see if one or both pedals are functioning. Does the system have air pressure built up ??
I don't know what you are looking at for $400.00. The treadle valves are a basic Bendix E3 or one of many rebuilt and rebranded ones like this one for $15.00 plus shipping.
http://www.ebay.com/itm/MIDLAND-KN2...ash=item4623706742:g:KlAAAOSwirZTwspr&vxp=mtr
Or a new one like this. -----> http://www.ebay.com/sch/i.html?_fro...C0.H0.XBendix+e3.TRS0&_nkw=Bendix+e3&_sacat=0
You may want to read this thread everything in it pertains to your brake system. https://www.heavyequipmentforums.co...5-Case-680-E-Air-Brake-Trouble&highlight=680E
I am happy to say the brakes are finally working! I love this site, you all are awesome! On to the next project!Please get the brakes working before someone gets injured or killed. Roll the backhoe bucket all the way out and drop the boom to stop and or hold the machine from moving.
That would be a good idea. Actually they look brand new. Not sure of what thickness is supposed to be when new, but they are definitely not thin at all.Have you checked the brake shoes to see what shape they are in? Chances are they're probably thin, should last awhile but when it's time to change them it'd be nice to have a set on the shelf, no? Just a thought, might take some time to source them. I'm trying to remember, but I don't think they are the same as truck shoes.
You have a few options. First one will take quite a bit of oil, and that's changing it several times until it cleans up. Second is quite a bit more difficult. That would entail flushing all lines and cylinders. Can be done, I helped my dad about 25 years ago do a 680E. Started by unhooking return line at the tank, started engine and let run just long enough until clean oil came out. Then proceeded to methodically unhook line by line at the cylinders and Dad would hold line in a pail and I would hold the control lever until clean oil came out. I don't suppose you have it parked with pads down, bucket dumped, and hoe stretched out, do you? That would have allowed you to have maximum amount of oil in the tank.
