OVERTORQUED
- Joined
- Jun 9, 2013
- Messages
- 218
- Location
- East Bay, CA
- Occupation
- Vintage Restos & occasional Tractors
, bite the bullet and call a Case tractor mechanic.
Wish it were that easy
With the electric pump we have installed between fuel tank and lift pump, we have 6-7 lbs with the electric pump on coming out on output side of lift pump. While cranking motor, pressure bounces between 25-30 lbs on the output side of lift pump. Only reason we are running the electric pump with external fuel tank is because fuel is contaminated in tank with water. (Replaced both filters and purged lines of bad fuel and took lift pump apart and cleaned everything out and put back on.) Electric Pump is rated at 35/gal per hour.OVERTORQUED ; Did you check the transfer pump output pressure while turning the engine with the starter ???? The one in the photo.
No i didn't... What should the pressure be? By the way, that's not fair...it looks like yours is out of the tractor and clean, lol.![]()
Feel like a plane ride? Lol. You were right, it started and ran the best ever, but only for about 15 sec. Repeat steps again? Still air in the system? Or... Tractor boneyard.That's decent pressure to run..
NOW.. check to see if its making its way TO the inlet side of the injection pump.. fitting on the right.. loosen the line and crank it over.. if fuel squirts out.. GOOD..
NOW.. go to the other fitting, on the left.. the overflow valve.. is fuel squirting out there, when you crank it over ?? IF YES,, GOOD..
NOW loosen the lines AT THE INJECTORS and crank the engine.. wait for the fuel to squirt out and tighten..
MAKE SURE the shut off lever is in the run position..
IF I have to type this out AGAIN.. I'm gonna find out where this equipment is and fly down and get it running my damn self.!!!! LOL
Now get to work..!!! lol
When you tighten it down does it seal it off? Or it would still suck air? The primer pump does seem like it has bad seal. But it did run before so....Just trying to come up with something that has not been mentioned yet. When you pump the hand primer pump does it leak fuel, it appears to be wet in your pictures, if it does then that would be where the air is getting in the system.
I would say your on the right track. Keep chipping away at it.Still air in the system? Or... Tractor boneyard.
The fuel is returning to tank. Clear line, i can see it. Its not plugged.I repeat RETURN LINE!!,, RETURN LINE TO TANK,, will not run if not returning or wasting fuel from last injector
If its the right track... My god how long is it? Cause it seems like ive been doing this for two weeks straight. (Whine,whine)I would say your on the right track. Keep chipping away at it.![]()
Cut it apart and put a couple o-rings in it and it sealed much better and tractor ran for a minute. Think it's still leaking though so going to look into maybe replacing.If leaks when you pump it , it will not seal off when you tighten it. This is probably your issue. It is sucking air. Replace or remove it and plug it off.
Appreciate all you alls input on this... Tractor gurus.![]()
