#5036
Thanks for that feedback.
Firstly, the 'R' stood for rubber mount - they used 'T' for track mount. Now for some obscure reason, RossCorp didn't start their model #no's at 1 like Madill. The 90's, 70's and 50's all started at 35 (there is a 7034 around but that's a story for another day) Anyhow, that makes yours the second one built, out in Feb 84.
Back to the flipper switch - I notice in the Pic, there is a button valve on the haulback lever - this is normally on the slackpuller lever and used to give full air pressure to slackpuller clutch for direct drive ie, dropline out and for taking up slack on inhaul - (the rest of time, the slackpuller is designed to slip) Now I remember spending a few days on a 50 way back that was plumbed something like this - all I can recall is thinking that it had been plumbed differently to suit a particular system. Taking that one step further, the mystery 'flipper' may be a mode switch which changes the way one or more of the levers or the button valve works. The TSY 255 has one that changes the haulback interlock position into a sky brake. What I suggest, try each lever individually in clutch on and water brake position and while in each position, flick the flipper switch and see if it changes its application - do it with the button valve too. Probably best to do while drums are stationary - get someone to watch WCBS and the slackpuller cutch. Also flip switch with motor off and listen for any movement.
There is a possibility that it applies the straw clutch so that the lever can be pushed for braking rather than using the peddle but I doubt it and I think you would have picked up on that anyway.
In conclusion, I hope the switch is still operable and hasn't been tampered with. Anyhow, look forward to results.
