Empty weight with 1/2 tank of fuel is 19,100 today with this trailer.Mostly done here. Expecting snow anyday now.
Surprised that International is so light. I had a 2574 dumping flatbed was about 25,000lbs empty.
I wish I was retired. Retired guys get to pick & choose the most fun jobs!This is the truck and trailer I drove most of yesterday. 1987 International S-1954 I think is the series. 185hp DT-466 engine with Allison MT-643 transmission.
This is 51,730# of harvested corn in the hopper bottom trailer:
She is slow but steady and reliable. Tare weight on truck and trailer after dumping was 19,660#.
If I’m not mistaken you live in an area similar to myself with steep mountain grades. When you load any truck to max gvw and head up a 10, 15, 20% grade your going to be crawling. There is a couple big hills on the highway here that the semi’s pull at about 20mph when fully loaded, my old 190hp diesel medium duties pull it at about 10mph loaded to max. Sure it is somewhat slower but also gets exceptionally good fuel economy, if it takes me a few extra minutes to get somewhere so be it.I wish I was retired. Retired guys get to pick & choose the most fun jobs!
I'm still answering 15 phone calls a day, people wanting a before cold weather major project done tomorrow, or at latest by the end of the week.
On another note, I've pondered many years why so many trucks seem under powered? I'm ignorant of heavy haul trucks with 10 to 12 tires, & certainly ignorant of 18-20 tired semi trailer rigs, but the six tired trucks & road tractors seem appallingly under powered.
I had a 1976 Chevy C65 nameplate 27500 GVWR, titled at 25999, I bought it with a 366 gas, changed it to a 427 gas. It was terrible on hills in general. Most of the 14 years I owned it it was essential to have the gas tank full to climb the steepest hill I frequent. Last year I owned it it got where I had to unload the trailer, or help it up with a pickup. Found a cracked O ring on a fuel filter cannister, that helped, but ultimately, I had to replace all of the fuel supply system. I could once again climb that hill loaded.
"New" truck is a 1990 GMC Top Kick, 28000 LBS GVWR. 3208 Cat is rated at 250 HP. "New" truck is able to climb, albeit very slowly. Allison does convert torque to get me up the hill, but I worry if the transmission will overheat.
Any theories why mid size trucks are universally underpowered?
You would be surprised how many of the local diesel "technicians" around here cannot perform a dry, and wet compression test on a gasoline engine at the least; let alone interpret the results once shown how. Never heard the term "leakdown", or "comparative analysis" in their training.If it would have needed a laptop to get it going i dont know if i could have fixed it. I still fill good about getting something going when some one needs it most.
True & true, on all but fuel economy. Last truck was horrible on gas. Route 7 lies reasonably level along the bottom of the valley. On trips to haul equipment or loads I'd see about 6 MPG. Anywhere else in southern VT it's uphill or down, 3 was more likely. Diesel fuel costs more, but I use less than half with the newer truck.If I’m not mistaken you live in an area similar to myself with steep mountain grades. When you load any truck to max gvw and head up a 10, 15, 20% grade your going to be crawling. There is a couple big hills on the highway here that the semi’s pull at about 20mph when fully loaded, my old 190hp diesel medium duties pull it at about 10mph loaded to max. Sure it is somewhat slower but also gets exceptionally good fuel economy, if it takes me a few extra minutes to get somewhere so be it.
With all that being said, there are usually a plethora of engine and transmission choices in class 6 and larger trucks. Depending on the application the original purchaser may have been going fo cheapest upfront cost or best fuel economy when they originally ordered a truck. When a guy like you or I come along and buy it used sometimes you have to take what you can get. I’m amazed at how many Ford medium duty trucks durring the 90’s were ordered with a 5.9l cummins. I’m sure it was largely based on the engines reputation more than anything, thats a tiny peanut of an engine for a MDT in my opinion.
Ouch. I could get easily get 50k of beans in the 28' double hopper trailers. They had 78" sides though.My one, full load to the elevator today grossed 66,200 pounds, 640 bushel of beans.
