What's your hoe doing?
Swetz
NJ/PA
Retired :-)
Well, I am now semi-retired, so I have been at my PA property for about 3 weeks now. Last week was a good one. I was able to move dirt the entire week. Then Friday came, and it has been raining on and off since. For example, yesterday alone I pumped about 3' of water from the hole where I am getting the dirt. I think I am shut down for a bit now.
The good news is that I feel as though I am about 80% done moving dirt:D:D:D. Hopefully we will have another dry spell and I will get all of the dirt moved. I really want a shop this year. I hate having the machines out in the weather, and more importantly, I hate laying in stones to fix them!
My final day of employment is July 5th...I cannot wait!!
NH575E
North, FL
Retired Machinist
Been retired 7 and a half years. Finally started slowing down. For a while I thought I might have to get another job so I could get some rest.
Willie B
Mount Tabor VT
Electrician
Mrs. B retired as of last week. I'm terrified! I still work & she NEEDS to have something going on. Big trip last weekend, two sons, two daughters in law, two granddaughters went to camp near Storyland. I opted to herd dogs instead.
Today she finished cleaning her classroom, then picked up a grandaughter. Tomorrow & Wednesday shes on grandma duty. Thursday she has no hard commitments, Hell will break loose.
materthegreater
VT
Does this mean you're going to give her the keys to the backhoe?
Willie B
Mount Tabor VT
Electrician
No chance! This is the easiest machine ever to run. She says it is too big. One machine ago I pressured her to help me prune trees. I'd be in the bucket, she'd position me. She promptly backed into the gravel screen, buggered a crowd cylinder rod.
Not that she can't, she won't. She regularly uses the IH 385 Utility with loader. It is the most cantankerous manual transmission! Years she puttered around using the hydrostatic lawn tractor with trailer, did fine going forward, couldn't back up. She insisted a wagon would answer her prayers, broke the tung off first try.
Swetz
NJ/PA
Retired :-)
I made it 3 months shy of 37 years, at this employer. I always said that I did not want to be working when I was 60. Worked 2 jobs my whole life in order to make this happen. Then I decided I wanted to buy an excavator, so I am over 60 and working 2 jobs still...LOL. But I do own an excavator :D. I own it free and clear, so time to retire! Somehow, I feel the desire to own more equipment is like gold fever, LOL.
Swetz
NJ/PA
Retired :-)
My neighbor has a late model bobcat CTL, and it isnt even the largest one. Had some retaining wall blocks on a pallet. Each pallet is 4K#. He lifts them on to the trailer no problem. At my end, i use the NH675E TLB, with forks on the bucket to unload them. I can lift them, but cannot steer the damn thing..LOL
In other words, these machines are quite capable for their size!
Swetz
NJ/PA
Retired :-)
man, my hoe just wants to leak!
I just resealed the connections to the loader bank, and I have verified it is currently dry:D.
So I was using the loader to move dirt about 2 days ago, and look back and notice the bucket is wet with hydraulic oil:(. Turns out the bucket curl steel tube has rubbed thru, I guess from the boom moving while I am driving the machine. Because of the extend a hoe, there is a curl of hose that kinda lays on these lines.
Anyhow, the tube is in stock at Messicks, so I figure it is a common problem. It aint cheap tho! $391.00 plus shippingo_O. I decided to give repairing it a whirl. All I have at my PA house is a 120V flux core welder. I did my magic best I could, and no leaks...whoo hoo! It did pull it a bit but fit perfectly. I wrapped the hoses that lay on the steel tubes with pipe insulation and electric tape. I do not think it will rub thru again soon. The other steel is also worn, just not that bad, so I wrapped the hose on that side too.
Oh, and I painted it with galvanize paint too.
Pressure tested it at max system pressure for a while, then reinstalled the tube, and now the machine is back in service:D.
NH575E
North, FL
Retired Machinist
Looks good to me. I tried brazing one but it continued to spray a fine mist under a load. I found one at the junkyard for a $100.
I welded one end of a stabilizer line with my mig years ago that is still holding.
