Digger, Its strange that yours would have more than one master link. There is no clip or pin holding it in. I'll try to give you the proper procedure for removing it but I am sure some one can give their two cents worth too. Here is the way I have always removed track pins. Run the dozer till the master pin is on the rear sprocket and pointed down at the floor. Put a large piece of steel (heavey, I have a piece of old rail road track) lay it close as you can get to the pin, cut a 4x4 or 2 2x4 nailed together, cut it to length so it will just reach the other sprocket on the other side. I cut mine about 1/2" short so I can drive wedges in it and keep it tight. Soak your pin down with pennetrating oil, take a medium size sedge hammer, then a punch just slightly smaller than the pin. ( got a old torsion bar off a car, as it is hardned and will not mushroom, about 1ft long, then get you a piece of 2x4 about 3ft long, bore a hole through it so bar will just fit. Have a helper hold the board, with the punch pin in it and then whack it hard with the sedge. Be sure and wear safety glasses. Usually this method will work, a few of them I have to apply a little heat. If for some reason a regular pin has been taken out and a master pin has been installed. I dont think you can still get it apart. So you have to make sure you take out the master link pin. I understand that when you take the tracks off and if you take it to a track press, and if you have one pin in the middle, that they have to start at the master link and work back. (thats what the track shop told me) I am sure others ,(maybe a track shop can give you better directions) The purpose of the large steel suupport in the back is so you will not spread the link and bend it causing it to jam, and supports sprocket and other components so alot of shock is not transmitted to them. Hope this helps.
