kc5gxc
Fine job on that thing, Mike. Thanks for the pic. I made some notes for when I have to do it.
Pete
Pete
It's for the horn. The glowplugs are operated by turning the keyswitch backward until the wire in the indicator glows. (looks kinda like the top of a saltshaker with a curled wire inside in the dash).there is a (broken) pushbutton, that is factory installed, on the front of the drivers enclosure, lefthand side, below the throttle and gearshift. It has 2 wires going to it from wiring harness, but there is No voltage at any time.
Orch X,
that is a great bit of info!!
I really need to find a manual for this thing...
I just went out in the cold dark night to see what happens when I turn the key CCW, I get the 2 indicator lights illuminated, but no glow in the 'saltshaker'.
I don't hear any sound that I would expect to hear from glowplug solenoid either. I will try this again tomorrow and see if it makes a difference in starting the motor.
thanks,
MikeK
It doesn't make any sound. The wire in the indicator breaks very easily when it gets old so it may be bad. A new one is about $20 +/- IIRC. Or you may not be getting any current to the system.:beatsmeOrch X,
thanks,
MikeK
Hello, I posted this in another forum, I think it was the wrong one so I am trying it here. My D20A6 won't pull on the left track. Right side pulls fine. Any ideas? Brake on left works fine, just won't pull. No noises, driveshaft spins. Thanks for any assistance.
where can i buy a shop manual for my dozer d20:Banghead
Dipstick locations.
Final drive oil level.
Track adjustment.
Fluid specfications..
Hope this helps some. Let me know if there's anything else I can do.
For some reason, I cannot get the picture of the dipsticks to download properly. Could someone just write which one is which? Thank you.
My D20 is a 24V system with two 12V betteries connected in series, located behind the seat.this might sound like a stupid question but is the dozer 12 or 24 volt:beatsme
:beatsme Could the left clutch linkage be stuck? :beatsme
and my question is do i need any tools to flush the radiator on my dozer.the reason that i ask is because i am far away from it right now and i need to know what tools to take when i go down and service it.
Thank you for your time and have a nice day.![]()
