Moving a Cat 15 miles
I think there's less chance of getting noticed on a gravel road. I'll check the road out first though. If it has a bunch of hills or is really rough I'll go on the pavement. Thanks for the responses.
BC Placer gold
Enderby, Bc Canada
Heavy truck, air brakes, low geared tranny….
probably good gravel roads. Nowhere near as sketchy as all the F150’s I see passing the scales here with rear end sagged out towing 30’ rv. Every one of these is over on rear axle…
JaredV
SW WA
I'm not going to tell you what you should or shouldn't do, Dave, but... We move 150 size excavator on tilt decks in the woods all the time, 2 and 3 axle trailers. Steep, 15% grades, sometimes more. With 8 or 10 tons in the truck and a Jake brake, you never really use the trailer brakes if you go slow. I once hooked up to a trailer after another driver moved a machine down a REALLY steep hill without a problem and when I pulled the hand valve to check the brakes, nothing happened. Nobody likes crawling under tilt decks to adjust brakes but I was happy to that time. Just sayin'
There's only 4 turns needed and straight roads if I go on gravel. 3 turns on pavement but the long road is a highway. If I do have to move it myself I'd rather go slower on the gravel road. If something weird happened to the truck I'd rather not be on the highway. Thanks for the replies.
I checked out the gravel road I could use. It's a little rough but not too bad. Has one bigger hill and a couple smaller ones. I did some distance calculations and I was way off. It sure seemed longer than it is. It's only about 7.5 miles not 15. If I went on the paved highway would be about 4.5 miles. Still going to talk to the gravel pit though.
AMBMike
Southeast KS
Cat herder.
I was wondering that but how much does 7.5 mi cost on the machine in road wear?
Almost nothing.
It'd all be in a forward gear under very little load on a relatively flat surface.
Depending on soil type and operator habits a typical dozer or loader will go thousands of miles before needing an undercarriage replacement. Most of those miles are under load or in reverse.
A loader on double or triple grouser pads will do no appreciable damage to a road surface unless turning hard under load on a hot asphalt pavement. On a cloudy day with the temp
under 65 degrees F it'll just leave small white marks on the surface that disappear after several vehicles drive over them.
terex herder
Kansas
Local dozer driver would drive his machine for several miles rather than bring his lowboy 50 miles to haul it. Asphalt roads he would drive in the road ditch.
It was over $900 to have it hauled. Roading it in 2nd gear would take a lot longer than 3 hours. I think the hoe on the back slows it down. To drive about 1/2 a mile to my former neighbours back field took 20-25 minutes. That was long enough. I think there would definitely be a lot of undercarriage wear driving that far. I'd probably get rattled and/or bored to death.
John Shipp
England
forestry contracting
Did you go ahead already with the $900? If you pay for a cheap return flight, I'll head over next week and move it the 7.5 miles back roads for you :)
I'm hoping to move it next week but it depends on the weather. Calling for heavy rain in the next couple of days. Driving out to the neighbours field was somewhat rough so I couldn't go full speed in 2nd gear. It was closer to 3/4 of a mile. With the extra weight of the hoe I'm sure the speed is slower than without it. Looking down 4 1/2 miles of highway is a long distance. Driving it isn't an option. I'd be crazier driving it than hauling it.
Dibs - beat you to it.
Dave do I need to come up there and move it for you?
Got a couple of friends in Calgary and Edmonton so I'll take 7-10 days off, move your machine the first day then vacation the rest of the time. Just pick me up at the airport.
Didn't even ask for a plane ticket. ;)
