Lull 2003 944E42
icestationzebra
try swapping the fwd and rev solenoids on the trans, should tell you if it is an electrical or trans issue. ISZ
icestationzebra
The C series used a WG100 drop transmission, 3 or 4 speed. The E series used a WG92 or WG98 trans, 4 speed. Transmissions share nothing in common. The page to download manuals off of the JLG website appears to be broken, but luckily I had saved a copy.
fwd: Y1
rev: Y2
1st: Y3, 4 and 6
2nd: Y3, 5 and 6
3rd: Y3 and 6
4th: Y6
FLorida
P. S. can test and/or repair the est controller
I did apply power to the solenoids that had no power and the machine does move in all gears. There is nothing under the seat but there is a circuit board on the side panel which has the fuses and relays on it along with led's. This does have quite a bit of corrosion on it.
laycobeau
Tulsa Ok. [email protected]
Lead electronic technician
Still think there is an EST controller somewhere. what does your shifter plug into and follow the wires. photo from different angle.
