Dalmatia
Hello,
It goes in reverse but not forward,replaced gear shifter lever but it didn't fix the issue.
I just did the testing from what Laycobeau posted and I have no power on M1 and M3. Any ideas?
I did apply power to the solenoids that had no power and the machine does move in all gears. There is nothing under the seat but there is a circuit board on the side panel which has the fuses and relays on it along with led's. This does have quite a bit of corrosion on it.P. S. can test and/or repair the est controller
Did you ever find a solution? I’m having the same problemHello,
