MR. KOBELCO
Resigned
- Joined
- Jul 31, 2008
- Messages
- 433
- Location
- CANADA
- Occupation
- PARTS & SERVICE MGR. AMOUNG OTHER HATS @ KOBELCO D
Hi Gents, just starting to check hydraulic pressures on my SK130lc. According to Kobelco the traction motors need to be stalled and pressures measured at stall. In order to do this it looks like they offer a special tool which locks the sprocket but our local Mazer Group parts guys are not familiar with it. I think they`ve only been handling Kobelcos for a short while. Was wondering if this is something that most guys just fab up to hold the sprocket. Looks like the proper way to do it is to lock both sides at the same time. Don`t want to break anything! From the Kobelco test procedure sheet I could not really see what it looked like. Also I presume that by secondary pilot pressure they mean pilot pressure right at the (for example) swing control valve. Do you T into that pilot connection or dead end it to the gage or does it matter.
hi,
this tool is nothing special - just take an old say bucket pin of the diameter which will sit in the tooth groove of your sprocket and when moving forward direction it will jam against the frame stalling the travel motors. can even stall it in reverse by placing the stalling pin on the underside groove which will then jam in the upward rotation.
cut the pin to make your two pieces, weld a t-handle untop for safety, when placing and stalling do not stand right in front keep off to the side.
pressures read when stalling both travels simultaneously together, h-mode, wide open throttle.
as far as secondary pilot prs you'd have to tell me where this reference was made in the data.
cheers!
