MR. KOBELCO
Resigned
- Joined
- Jul 31, 2008
- Messages
- 433
- Location
- CANADA
- Occupation
- PARTS & SERVICE MGR. AMOUNG OTHER HATS @ KOBELCO D
I have a Kobelco SK045 Ser. No PY02469......The hydraulic fluid has a round bolted down plate on the top of the machine, which i presume is the fill cap to the tank.......In the battery compartment right in front of that is what appears to be a sight glass and about a 5/8 bolt right next to it......I'm assuming the sight glass is for the tank & the the bolt is the pressure relief......Are my assumptions correct......Thank You
hi,
if this bolt you describe is in the tank itself it would not be the relief.
your machine likely has a pilot system relief and a seperate relief for each hyd pump.
the pilot pump relief is likely in a manifold at one end next to a couple solenoid coils.
the main hyd pump reliefs will be part of the main hyd control valve.
each circuit will have overload port reliefs.
circuit protection when the function is not being utilised.
cheers!
adam
