Ryan6585
Took apart to change final drive, was adjusting brakes and tightened one side up too much. Can’t get it to loosen from the outside 1.5 inch pipe plug with a screwdriver, any ideas?
Sounds like the brake lever adjusting screw (#4 in screenshot) is mis adjusted allowing the linkage to go “over center“ . See (2) screenshots below.OK so the adjuster link you are taking about, when I’m pulling the right steering handle back if I go too far back the handle gets really easy like no resistance at all and the brake stays stuck, I have to go with a screwdriver and push the adjuster back up and it releases the lever coming out of the steering box going to the steering handle.
