Good healthy carnage
785D Haul Truck - 125 hours from new. Final drive let go and locked up. The truck was loaded and stuck right in the middle of a haul road at the time.......
IIRC correctly it was a bolt from one of the 2nd reduction planetary shaft retainer plates that fell out and went through the gear train. CORRECTION: It was a 2nd reduction bearing failure by the looks of it.
Basically the boys went in the housing with a shovel and dug out the debris.
Acoals
Wisconsin
A problem built into air disc-Heat. The cavity where the seal is small plus the rotor is tucked inside
the drop center of wheel. Which allows for very little cooling through the rotor veins. Depending
on brake usage the seals cook, especially the National type OEM. Air disc works in some applications,
out here in many cases trucks are spec'd with disc on the steer drum on tag and drive. My experience
with air disc-it's definitely not cost effective in a fleet-OO maybe.
So what is the benefit of disc? Isn't heat dissipation the point of disc?
NHTSB--stopping distance-which is really negligible in the real world, not on a test track.
Trucks are not required to have air disc, but many jumped on the band wagon with sales pitch.
Problem is the thinner the rotor gets the faster it heats. Drums have x amount more
friction surface and a open cavity for air, Disc doesn't do well in stop and go traffic.
The real benefit of air disc is the manufacture keeps your wallet vacuumed, a complete brake
replacement with disc on a three axle tractor can hit $8,000. Drum $2,000.
Acoals
Wisconsin
Sounds about right. The Fed will be mandating that soon enough . . .
I wish I still had pictures of the D11R I had to cut the planetary carrier out of it to get the axle shaft out to pull the final. That was the worst exploded final I ever came across.
I’ve seen a few haul truck finals that had to be gas axed apart to get the guts out. Last I heard Reman 793 finals were going for $200k a copy not including the Core Charge Credit, trash one and it would probably be upwards of 250k.
Last fleet I worked with were 785D, small by mining standards, only 150 ton payload. A planned component replacement at 18k hours for everything in the power train from the radiator through to the final drives, steering overhaul, suspension, & dump body cylinders came to just short of $1m a copy in parts. We had 35 trucks and basically at any given time one of them was going through that process.
We could turn one round in 30 days, so 12 trucks a year. With each truck working on average 6k hours each year the math worked out perfectly.
Acoals
Wisconsin
Two curious questions; What were those 785d's new, and how many times would you overhaul them like that before it wasn't worth it?
Tyler d4c
Salix Pa
I got bored doing certified power trains at the cat shop I worked at after 2 or 3 months id probably be looking for more exciting work
ahart
Indiana
Side note on rebuilds, it may no longer be worth it on the site it’s on but we’ve moved plenty of 793 trucks across the US to a different surface strip job where they were put back in service and reframed with over 100k hours on the frames. When I left that strip job, they were exchanging engines/torques at 21k-22k hours in a 793C. As the budget gets tighter due to coal demand going down, those hours get pushed more and more. We would almost always swing a 3508 in a D11 at 12,500 hrs no matter what but I’ve heard they are pushing them to 15k or more these days and just rolling the dice on the core. And Nige is 100% correct, on a job that size there’s always a 793 and a D11 getting an engine changed. Seems like we did very few of them in the shop too, most were done outside in the parking ditch.
