Good healthy carnage
Acoals
Wisconsin
The pinion gear lost about three teeth, chewed up the ring gear pretty good too.
I can't say I really know how to mess with the pics much, I just point the phone at it and click.
Cheap "old" Geezer
Two drivers at The Yard, front bumpers crumpled since I left last time, less than year. Come to find out Two Each under a year. Tires holed in less than three days on trucks. One Western Star tractor Air Disc brake, 6th steer axle seals(both) in under a year, Five on drives. 120,000yr truck.
How exactly does a driver wipe out axle seals?
A problem built into air disc-Heat. The cavity where the seal is small plus the rotor is tucked inside
the drop center of wheel. Which allows for very little cooling through the rotor veins. Depending
on brake usage the seals cook, especially the National type OEM. Air disc works in some applications,
out here in many cases trucks are spec'd with disc on the steer drum on tag and drive. My experience
with air disc-it's definitely not cost effective in a fleet-OO maybe.
ahart
Indiana
Rear idler on a D6N, they finally quit when one side of the idler shaft was completely worn off and the idler kicked sideways. Something tells me they heard it making noise before it got to this point. Frame had to be welded up and new dowel holes drilled.
