Deas Plant
955K Decelerator Pdal.
Hi, Fabman72.
Welcome to the forum.
I have never seen a 955K or L with a decelerator pedal, only a hand throttle just inboard of the powershift control lever. As I understand it, they had a different power-splitting arrangement in the torque divider, sending 70% of the power through the torque converter and only 30% direct to the transmission. Most of the larger Cat dozer had a 65/35% split which made them slightly 'snappier' to operate but also slightly more susceptible to damage from not decelerating. Personally, I used to throttle down and back up with pretty much every change unless I knew that the weight of the machine was going to be working with the change in direction to lessen the shock if I just paused for a second or so in neutral before selecting the opposite direction.
Dozer575, you operate your mental D8H any way you like. I'm not paying your imaginary parts bill.
Hi, Knucklehead.
Yes, it was fairly common practice in days gone by to put some lengths of cable into the tops and bottom of pipe legs for a canopy, especially if the dozer happened to be working in rock and the canopy was basically only for weather protection. The cable sections allowed the canopy to move around without the legs snapping due to movement and fatigue. Most such canopies only had a canvas top laced to the top frame.
I'd love to see some photos of that old girl. I've always had a bit of a soft spot for the A-C dozers. I think I could spare the time to read the story sometime too, if you want to tell it.
Hi, Fabman72.
Hi, Knucklehead.
