ISO 32 is approximately SAE15W, not 10W. You really need an ISO 25 or thereabouts.The machine operates only about 150 hours a year.
Change what's in the tank and plan on changing it every year, maybe twice in the first year.
Unfortunately not. Draining lines, cylinders, etc, will always involve disconnecting lines and can get very messy. It is possible, but it is neither easy nor quick.is there a way to drain the pump, lines, and pistons without disconnecting or damaging anything to get as much bad oil out as possible?
