ja_cain
Does anyone know off hand what the standard blade width? None angle/c frame setup. Thanks.
Because the military 61G tractor corresponds to a commercial 94N machine with a Serial Number below 5191 they all would have been originally supplied by Caterpillar ftted with a D333C engine. Only the tractors that went through the SLEP program would have been upgraded to the later model 3006 engine with direct injection, the same engine model that was fitted ex-factory to the 94N tractors from machine 94N5660 onwards.For the military version, it's 133 inches as measured on mine and as stated in the military TM (technical manual).
Note the mention of a D333 engine so I would assume it's quite possible the early ones where shipped to the military with that engine or the military would not have put in their manual. That's a new bit of info for me on these things...
Thanks for the info sir! Preliminary quote I got from my cousin. Not sure what the permit costs, but that doesn't seem too bad.For the military version, it's 133 inches as measured on mine and as stated in the military TM (technical manual).
Nige- In my military parts manual, I see 4 engine arrangements. Maybe you or someone else can decipher what they are to see actual engines offered in the military version. I have the 5R8357 but I can also look my S/N up on SIS...don't know how to look up A/NBecause the military 61G tractor corresponds to a commercial 94N machine with a Serial Number below 5191 they all would have been originally supplied by Caterpillar ftted with a D333C engine. Only the tractors that went through the SLEP program would have been upgraded to the later model 3006 engine with direct injection, the same engine model that was fitted ex-factory to the 94N tractors from machine 94N5660 onwards.
Thanks Nige! That's so much better. I'm liking the prospect of getting D7F over a D6C everyday. Nice having that float function too.
You're awesome! Really appreciate it. I think I'm going to make up a binder with all of the resources that have been shared with me on this site.JA-
Download the military user manual from this link as it has all the info you're looking for and then some:
For instance on page 54, you'll see a Circuit Breaker Reset Switch which resets a circuit breaker that protects starting and charging circuits. I seriously doubt you'll find that on a non-military dozer.
You'll also find all the parts and repair manual offered on that website if you pick up that military D7F. And remember those manuals were written for non-Cat trained Soldiers so they are fairly easily to understand. If you buy the D7F, I can help walk you through how the manuals are laid out. Fairly intuitive once you know the US Army technical manual numbering system.
Aww hell, you're already an expert on TM's. I started out as an avionics repairman (helicopter navigation radios) back when radios were mostly discrete components. Nowadays, way too many chips and circuit boards for me to follow. And it seems like you already know about heavy wrenching in a field environment. Torque rods on 5-tons are a beast- I may need to get your secrets! I have an M923 with the NHC-250 Cummins that is more of a parade truck than anything else. But yeah, it sounds you'll do just fine taking care of any dozer you pick up. Just be patient and find a good oneMy only regret is not writing up my method and submitting for publication of removing torque rods on 900 series 5 tons in the field with a porta power and big add pipe wrench. I was known as the torque rod master even though inwas formaly trained as a ground radio repairman. Every deployment I always gravitated towards wrench turners. Lol!
I got a Navy Achievement Medal for my efforts in Greece/Macedonia/Kosovo. It was the crowning achievement of my second deployment with the 24th MEU (that and picking up E5 in Shivta Israel). My best friend works for Leiberr and I was his A driver all the way to the Kosovo/Serbian boarder. It was an epic deployment. My method is stupid simple.Aww hell, you're already an expert on TM's. I started out as an avionics repairman (helicopter navigation radios) back when radios were mostly discrete components. Nowadays, way too many chips and circuit boards for me to follow. And it seems like you already know about heavy wrenching in a field environment. Torque rods on 5-tons are a beast- I may need to get your secrets! I have an M923 with the NHC-250 Cummins that is more of a parade truck than anything else. But yeah, it sounds you'll do just fine taking care of any dozer you pick up. Just be patient and find a good one
All my deployments were in countries that began with vowels. But since I was aviation, I was in the air most of the time and avoided the convoys...always felt sorry for the guys driving trucks on those long convoys. We would sometimes see them stretched over the horizon (we were only flying 100-200 feet above ground) and we'd try to fly ahead and give them any reports on things we saw. They always appreciated any top cover we could provide. Our TM's rated the 5-tons at 5-tons for offroad and then allowed a 2x factor (10-tons) for on road use. So if you're squatting a 5-ton and popping torque rods...then yeah, I'd say you were overloaded just a tad bit.What an epic convoy. Damn truck broke a torque rod 2 different times. It was super sketchy especially with the truck being way overloaded with all of our tools. She was definitely squatting. Driving from the shore of Greece all the way into Kosova is like driving through 3 WV's. I was periodically slapping him in the face to keep him from falling asleep. Lol. Sorry for the derail, but the mention of 900 series 5 ton just brings back too many memories.
