Okay- time for my good deed for the day.
Regarding military manuals, at least Army ones, these are free if you can find the right place to download the pdf. For the D7F, the Army Operator manual is TM 5-2410-233-10.
I'll decipher for you what that TM number means.
TM = technical manual
5 = The branch in the Army generally responsible for writing the manuals, doctrine, etc. In this case 5 means Army Corps of Engineers.
2410 = Class of the equipment. In this case 2410 is tracked equipment.
233 = The specific model of equipment which is the Cat D7F. 237 is the D7G
10 = Operator level instructions and maintenance. This informs the equipment operator how to basically start, run, and maintain the machine in the field.
In the Army, the "dash 10" always meant the user manual and it had to be located on/near the equipment being used for easy access by the operator.
The -20 is the next higher level of maintenance that can be performed by unit's mechanics that couldn't (or shouldn't) be performed by the operator in the field. This work was generally performed in the motor pool (and it was quite common for the operator to join in and help with the heavy lifting and dirty work!)
There are other -20s manuals such as -23 and -24 that describe step by step unit level repair procedures. If there is a P at the manual (really only for -23P and -24P), that is the detailed parts listings and diagrams but no procedures. You generally have both sets of manuals side by side when working on the equipment.
After that, there are -30 and -40 series manuals for depot level repair or repair work beyond the capability of the unit in the field. This level of maintenance is performed "in the rear with the gear" or way out of harms way. Again, you'll find both procedures and parts manuals in these series.
So here's my good deed: Search on the TM number without the last couple numbers. In this case "TM 5-2410-233". You can cut/paste this into your search bar: "TM 5-2410-233 type: pdf" which shows only PDF's available for download. Play around a bit and hopefully you'll find more info than you'll ever need for your new toy.
Edit: Forgot to mention that you won't find every series of manual on every machine. Some had them all, some had just a -10. No idea why, it's just the way it was. But good luck hunting on free manuals. Also pm'd you a link to make it really easy...
