Nitelite
Back at it!
We got a little bit of cooler weather, but not much. I was able to put in about five hours between an early morning session and a late evening session.
The cut line marked
![951 sprockets 1 1157.jpg 951 sprockets 1 1157.jpg](https://www.heavyequipmentforums.com/data/attachments/124/124511-ed5349ae16ed734adb8efa6a737914b7.jpg)
I removed the cap to be able to access the dimple in the end of the shaft to center up and draw the cut lines using soap stone in a fabricated set of dividers.
![951 sprockets 1 1159.jpg 951 sprockets 1 1159.jpg](https://www.heavyequipmentforums.com/data/attachments/124/124512-a4c7ca54c7e8cb20a27416579021fafc.jpg)
I used the gas ax to make the cut. I ran out of oxygen just as I finished the cut.
![951 sprockets 1 1160.jpg 951 sprockets 1 1160.jpg](https://www.heavyequipmentforums.com/data/attachments/124/124513-13c6e7dee02c9fcb7729f1d98045e915.jpg)
I need to trim off about 1/4" all the way around and then do some V grinding. I will have to pick up more oxygen before any more progress can be made.
![951 sprockets 1 1162.jpg 951 sprockets 1 1162.jpg](https://www.heavyequipmentforums.com/data/attachments/124/124514-0f090f62f6ad616fea66c451db4cb07c.jpg)
The cut line marked
