Case 580 sm ii
domorguy
michigan
What do you recommend to install this bushing on the loader bucket tilt cylinder of the case 580 smii ?
Thank you
Tinkerer
usa
I would guess that the loader arm needs to be removed.
Did you ever find a power-shift module that we tried to help you with in your other thread about this machine ?
Or is this a different machine ??
alrman
SE QLD Australia
The bolts going through the links & hollow pins must be removed to seperate them from the cylinder trunions.
Usually the bushes in the loader frame, at the pivot point are the ones that need doing, as the factory fitted bushes are made of a bronze material with a very short life.
Goes without saying, make sure the bucket is on the ground & there is no load on those linkages before you start undoing things.
