About how much do you pay for the cores? And what is most desirable or sell-able?
BC Cummins--max is $500 bucks, normally I won't give more than $300. People have the idea
there worth $1,000 to $1,500---Not even. 50% of BC cylinder heads are either cracked or have
already been rebuilt several times and are too thin to deck. New height of head is 4.375 most
are at 4.345, minimum is 4.340. The other is the block may already have the worthless Cummins
counter bore repair sleaves, if so it's junk.
I did. BXS block could care less what the Elog s/n is.
Really the issue is 6NZ wasn't the only good engine, for some reason everyone got a boner over
those numbers.
Same with building a BCIII with 625 CPL---there are ten or so CPL's that are timed the same & use
all the same parts, only difference is the pump & injector settings, and the pump is nothing more
than which torque spring it uses, flow rates are pretty close to same. Turbos depended on which
jakes were used.
As far as B model Cats go----Really it's not the prefix--it's the performance specification {Perf Spec}
listed below AR#. For a B model the best perf spec was one for a 4MG-425 hp. Which I will look up
and post here.
What's funny about this the 4MG @425 hp---it was the boner maker years ago now its just limp--
Soooo Last Year.
