Wait until have washed clothes 2-3 times and can still smell it on them!
MIG uses DC.Aluminum requires AC, correct?
What does that mean??washed clothes
Used final drive oil is the strongest I've smelled. The oil in this differential really wasn't that bad.It’s funny that gear oil, whatever the weight, doesn’t smell that bad, till it gets used.
Someone should do a study on how long it takes, to smell nasty?
Lol
I made a drill guide and that helps a lot. Once I drill through the broken piece, it usually comes out with an EZ out. One of them wouldn't and I had to drill it to size and use a tap to clean out the thread remnants.Just practice work!!
Lol
I don't know the coupler, mine has a conventional coupler. They don't last real long. I probably have to replace them every few years. Quite handy, I had a front tire on the backhoe come off the rim. I didn't have the hose for unknown reason, had to drive a few miles to get it.Can this fitting on the air tank be used to connect an air hose for filling tires, using a blow gun, etc?
