Branson1822
Thats what it was thanks
I pulled the clutch valve off and the valve and spring that works with the clutch pedal seems fine but the one beside it not sure what it’s called. It’s real catchy and slides really hard.
The one that the file was pointing at it, slide super rough, and it was hard to get out of there
Were you able to free up the sticky valve in the clutch valve ?Are you able to clean everything and free up the sticky valve ?
Polish the valve and clean the bore in the housing as best you can . The valve should slide smooth in the bore.I think so well they still be a little grabby since the have the prong on them or should they be smooth
What was sticking up the valve ? rust, dirt or something else?Ok is there anything else there I need to be looking for
