1984 jd 640 transmission problem
Branson1822
Ohio
I pulled the clutch valve off and the valve and spring that works with the clutch pedal seems fine but the one beside it not sure what it’s called. It’s real catchy and slides really hard.
Branson1822
Ohio
The one that the file was pointing at it, slide super rough, and it was hard to get out of there
Branson1822
Ohio
I believe number 7 and 8 is it
Diesel Dave
Ontario Canada
Are you able to clean everything and free up the sticky valve ?
Branson1822
Ohio
This is the clutch
Branson1822
Ohio
Still clutch
Branson1822
Ohio
This is the other housing
Branson1822
Ohio
Just a picture of where it came from
Branson1822
Ohio
I think so well they still be a little grabby since the have the prong on them or should they be smooth
