Hendrik
I would go with number 1 as the problem with number 2 is that you are likely to tip the machine.(1) back up the hill and keep the machine level by digging over over the back of the machine with the blade lower than the machine to keep it somewhat level. I understand this may stress my tracks by backing up the hill and digging over the drive sprokets is to be avoided if possible
OR
(2) drive forward up the hill & dig over the front of the machine but with the machine on an steep incline, slewing up and down hill.
Which technique is easiest on the machine?
Working an ex when it is off level is a dangerous practice, as the machine has both push and pull forces during a dig. As you push the bucket in it will push against the ex and then as you pull the bucket out it will pull on the ex. If you are off the level you will not have the same digging power as when the machine is sitting horizontal.
Excavators are build strong enough to enable them to work by sitting on the blade and part of the track.
However if you can, build some pads to work off. You can still then use the blade for extra support but have most of the tracks on level ground.
To really be able to give some more advice we would need to know what you want to do on the side of the hill and how you plan to go about it.
And whatever you do make sure you think it through and make a decision beforehand as to what you would do if the machine does go. This depends on your surroundings.
