What's your hoe doing?
Willie B
Mount Tabor VT
Electrician
TEETH
I find myself often raking the ground to remove rock on or just below the surface. New teeth work OK for digging them out. Picking up a rock to load it in the truck can be easy, or hard depending on its size. I have an Amulet thumb, forged into it is CT Series. I feel it is too long for my bucket, and the geometry isn't right. I've got an idea for reshaping the thumb. I feel like a seven year old eating corn on the cob, thumb is useless for small rocks under 16" diameter. Those, I find myself pulling them toward me, can't get under them to get them in the bucket. Even digging a hole to scoop them out of fails to get rock in the bucket without gravel also. Worn teeth make it even worse.
I've kicked around a number of ideas to improve the situation. I've considered building a heavy thing that I'd move around as needed to push rocks against like I would with the blade on a mini excavator.
I once welded extensions to the teeth to lengthen them. It worked great, but eventually they broke. No welds failed, the scrap cutting edge I was using broke an inch or more past the weld. I'm considering a better choice of steel for another try at it.
Anybody got a better idea?
What would you use for the extensions. Stuff I used before was 3/4 thick bolt on edge for a road grader.
Willie B
Mount Tabor VT
Electrician
TEETH
I find myself often raking the ground to remove rock on or just below the surface. New teeth work OK for digging them out. Picking up a rock to load it in the truck can be easy, or hard depending on its size. I have an Amulet thumb, forged into it is CT Series. Salesman claimed they make the thumbs for Case optional thumbs on new tractors. There is a lot different about factory Case thumbs. I feel it is too long for my bucket, and the geometry isn't right. I've got an idea for reshaping the thumb. I feel like a seven year old eating corn on the cob, thumb is useless for small rocks under 16" diameter. Those, I find myself pulling them toward me, can't get under them to get them in the bucket. Even digging a hole to scoop them out of fails to get rock in the bucket without gravel also. Worn teeth make it even worse.
I’d consider looking for a clam shell hoe bucket. There was one on FB marketplace for a 580 L a month or two back. Think it was only 500 bucks and it was 24” I think.
I was messaging the guy and he was actually responding, then I decided I didn’t need it as I have a hydraulic thumb already but the price was almost too good to pass up.
That and it looked to be in excellent condition.
Deere500a
Castro Valley ca
Willie for the thumb might be worth checking a extra capacity bucket like old Fords used plus find'em cheap to modify. Wain Roy 4/1 hoe bucket is one of the original & new brands use hydraulic motor for clamp instead of hydraulic cylinder past see'em on gov/park machines time bucket was 12k us newScreenshot_20260703-101519~2.pngScreenshot_20260703-101404~2.png
Willie B
Mount Tabor VT
Electrician
I think this is the biggest shortcoming of a backhoe compared to an excavator, the loader bucket is on the wrong end. If it could be used like a broom & dustpan it'd be much more convenient. At least an excavator has a blade you can push the rock against.
I checked out clam buckets, way out of price range unless I could find a used one.
aighead
Dayton, OH
Not really the same use case and not terribly friendly unless you have a helper but I got a set of log tongs I haven't tried yet. My plan is to use them to move some rocks around. It looks like it should work but they may get bent up pretty quickly. It was a 90 dollar gamble. My solution has been a bigger rock to scoop against and it works some, but without a thumb placing them, after picking up, is a crapshoot.
Willie B
Mount Tabor VT
Electrician
I find a big pile of rocks, I can get in the bucket size rocks in. Find as I work a pile it gets too close to the back of the tractor to reach. If I'm not careful it ends up under the swing tower.
I get ads for a strap invention to lift big rocks. I'm tempted because it is hard to place rocks the side up or swivelled where I want them. Again I don't think it'd be very convenient to use if you don't have a second person.
I have found a piece of 3/8" cable with a very thick ring at one end works reasonably as a choker to lift big ones won't fit in the bucket.
aighead
Dayton, OH
I got this- https://a.co/d/0ilfCm21
Again, haven't used it yet but use case looks similar to the net, though I think I should be able to very specifically set a rock where I want. The net looks like it could be a bit precarious, and both net and log tongs would benefit from a helper.
Willie B
Mount Tabor VT
Electrician
I can't find it at the moment. This thing pops up often. It is two loop straps with short straps holding them together. You position them both sides of a rock, and slide the shorter straps down snug on the rock. No need to get it out from under after placing the rock. Tempting, but it's kind of specialized to rock landscaping.
Deere500a
Castro Valley ca
Rigging is it's own art.A new straps WLL drops fast from single straight line lift to a basket & side load the eye stitch can fail or a cut release stored energy is dangerous. 3' Boulder ball park 2000lbs -/+ lot of weight for a old hoe,lift center of front bucket,rear bucket full of dirt add terrain once the rear tires start to float you're on the front axle pivot easy get pulled over. A chain g7 can take a lot of abuse. 2 chains twisted together can make a basket to lift. Screenshot_20260707-102148~2.png
