What is this? (Takeuchi TB25/TB250?)
Earth Worm Jim
Jackson, Tn
I recently acquired an older Takeuchi?Mini Ex. My best guess (based on the serial # on the engine)is that it is a 1984 model. Its in pretty decent shape other than paint and seat, but it still needs a little love. To be honest im a bit confused as to what it actaully is. The counterweight says job-ace but the tag says takeuchi, and if i google tb250 it always pulls up the new ones. I have seen a few pictures of machines like mine but no usefull information. I think the job-ace is the euro version or it was pre takeuchi. Im wondering if anyone has a service/parts manual for this dude so i can have fluid, filter, and other standard maintanence information. Any help would be much appreciated.
Jim did you have any luck getting any details on this piece of equipment. In the twelfth hour of buying the same piece of equipment
uffex
Lincoln UK
Admin
Good day
A contact posted this to me some time ago it looks similare may help , if not try an appeal to "Toolking"
Kind regards
Uffex
  • TB025 PE3-PaMan.pdf
Uffex, awesome, it worked. seems you had your rig for at least 1 year. while it looked super clean, how has it performed? have you put a lot of hours on it?
uffex
Lincoln UK
Admin
Good day Jeremy
From time to time we help out those in the world trying to fix there machines during one such instance the fellow posted the information to me , real pleased if it helps out.
Keep smiling
Uffex
i found another thread where they as that the TBxxx unit were good but stay away from models TBOXXX
see number plate attached what model do you have
and thanks for hte help
tool_king
new jersey
road mechanic owner
That looks like real clean machine .I will take a look in my files and if I have books on it to send you .
calinb
N. Central Idaho
I just got this old TB25. It's not so clean so I could really use any books or .pdf manuals. On the other hand, I only paid $4k for it. Like the OP, it took me awhile to figure out that although the data plate says "TB250", most people refer to it as "TB25", like the decal on it says, to differentiate it from newer and completely different TB250s. My data plate:
Takeuchi TB250
Serial number ppp00921d
3T84HLE-TBS
Engine # A5764
Working rate 2.5 ton
It's a smoker but the smoke isn't so bad once it warms up. The ring blow-by that's going out the crankcase breather hose is worse! I've got a makeshift air / oil separator on the breather hose to catch the oil, but it's going to need a top-end overhaul soon (at least). Anybody have recommendations for parts? I'd rather not buy Chinese but Yanmar parts might be out of sight expensive. I read somewhere that John Deere used this engine too.
The Hobbs meter says 3200-something hours and it's still recording time and looks original so maybe correct and no need to do bottom end work. It's my first piece of equipment but I've spend a lifetime of my spare time overhauling cars, motorcycles, pickup trucks and airplanes (and build a homebuilt airplane too) so now I've bought an old smoker and joined this forum to broaden my horizons.
I took the stick cylinder to a shop to have it re-sealed. It was pumping fluid overboard. The other cylinders seems to be pretty good with only minor wetness, at worst. Next time I'll attempt the cylinder tear down myself, but I wanted to get up and running with it ASAP so I gave the local shop $350 (yikes).
It has a USA Attachments thumb on it. It took me a while to grasp how to make it grasp! (Diverter control toggle lever is next to the travel speed left foot heel pedal and then right foot left/right boom swing pedal controls the thumb.) The only control I don't understand is a momentary pushbutton switch on the top of the right (bucket/dipper stick) stick. It looks like an add-on. Oh well--can't be too important. I got the rest of the controls figured out.
I apologize if the terms I'm using here aren't quite correct. I'm just learning.
Thanks for any advice or tips. I'll need 'em!
Here's a pre-purchase photo at the seller's place.
-Cal
tool_king
new jersey
road mechanic owner
Takeuchi TB250
3T84HLE-TBS
Engine # A5764
-Cal
What's your email address ? I can send you the manuals.
Travis Marsh
California
Do
Do you happen to know where a stamped serial number is on the machine?
