Volvo EW180C issues with arm and bucket not having power
pados1002
Greece
Hey guys, i just bought an EW180C volvo from 2008. First thing i did was to send the machinery in Volvo dealer for a big service and a control pattern change kit, because i wanted the backhoe pattern as well. The dealer checked pressures and they were in spec. Today, first day of having the chance to test the excavator, i found out that the arm cylinder has not enough power to either push or pull function. Same happens to the bucket. It will function up to a point where the load increases and then it stops. However the weird thing is that neither of the 2 make the pump or the engine bog or make them work hard. Feels like when it hits a certain load instead of keep pushing it just disengages the pump or some kind of pressure relief. What i mean is that i expect from an excavator, to be able for example, to grab with the bucket on solid ground and pull it self from a muddy terrain with the arm. At least the old O&K did that with ease. I 'll contact the dealer of course but something 's going on here. Same happens to both backhoe and excavator pattern.
pados1002
Greece
Thanks for the quick reply! I m pretty sure about that because i push it hard enough and the pin also locks properly so i gues it 's pretty unlikely. About the debris however, what 's the possibility of both arm and bucket spools being clogged? Hydraulic fluid was also changed in the maintenance.
pados1002
Greece
Hm... Boom and swing however seems to load the pump and engine properly.
One more thing, that however i have no clue if plays a role, is that on pattern swap valve the 2 sensors are not connected anywhere.
funwithfuel
Will county Illinois
Mechanic
Those sensors tell the VECU what control pattern you're in. They're not plugged in? That's a bit of a problem. The machine doesn't know when to stroke or destroyed the pump.
Ben Witter
On the outside
The sensors on the pattern change are primarily there as an indicator which control pattern it is in. There should be connectors somewhere that would allow them to plug in, but you may have to change some parameters or change programming in the machine for them to function. That still should not cause individual functions to misbehave.
I would say you will need to check cycle times and working and LS pressure for each function and in both directions before you can determine what is faulty.
The pattern change valve could affect the function of the arm and boom if it were installed incorrectly or it is faulty. Did the machine function properly or the same before the valve was installed?
pados1002
Greece
Unfortunately the moment the machine was imported was also sent to the dealer service. We did not do any operational work to test the functionality. But the pattern change kit was installed brand new from the dealer.
One more thing (not related to the functionality): Any idea where the back up beeper should be located, if there was any and if you know the part number? Today I had an inspector to check the machine in order to proceed with the papers and he asked me to reverse and obviously no beeper.
funwithfuel
Mechanic
That should have read "destroked" vs destroyed. I apologize for any confusion this may have caused.
Had any luck measuring pressures and recording cycle times?
pados1002
Greece
Not yet unfortunately. As I said pressures was tested before installing the pattern change kit and were in spec. After that I think they did not check again...
pados1002
Greece
Guys for you who may know... I m thinking an other solution instead of repairing or trying to repair my spool and housing. What if I take a slice and attach that to the Mcv like the other functions are attached, for example the 2-piece boom. And reroute all the hoses there. Do you think that this can work? Just some thoughts.
funwithfuel
Mechanic
You probably have an auxiliary function unused. To run hammer or shear. You could repurpose that bank, just know , you won't have fine control, that spool does not have extended lead in cuts that promote feathering and grading. It's more of an "open-close" spool. Any fine control will be dictated by the RCV inputs.
Ben Witter
On the outside
You really need to get someone to work on the machine that has an idea what they are doing. You need to check working and LS pressure while using each function in both directions. You state that the dealer said it was in spec. What is the number the dealer measured as "in spec" is not a value.
There should be no need to try cobbling this machine to work nor would I try that.
