ROAMER_AUS
Engine doesn't want to start.
It cranks, and wakes up for a moment when sprayed with start spray, but no proper start.
There is plenty of fuel coming from the lift pump.
No fault codes are coming up.
On display I can see live RPM when cranking, maens that EECU is alive.
Checked electrical signals on the injectors - nothing, no voltage pulses.
Supply to EECU checked, grounds checked. Wiring to injectors checked.
Any ideas?
What else EECU needs to start impulsing signals to injectors?
Thanks!!!
Any ideas?
Thanks!!!
