Dnr
Volvo A40D no start dash comes on and stops at 6th dot. No power to V ecu C ecu T ecu E ecu. Has power at relay 1 no power to fuses 24 25 4 and 10 11 12
I accidentally put P in the 19 spotWith key in on position I have power at 15-30-DR-R and no power at 50-P-19 and with key in starting position I have power at 30-DR-50 and none at
19-P-R-15.View attachment 330021
I’ll have a look.hope this helps
I had forgotten to mention that it was not a bad fuse panel or the wiring harness, we had replaced the fuse panel and taken the whole wiring harness out of the cab and checked it, had no problems in the wiring harness, It was actually a bad VECU.It has a bad fuse panel and a bad spot in the wiring harness inside the cab.
