That's theoretical % of pump capacity, depending on preset volume desired. That's why a flowmeter is so important. Deadhead is not running. Flow @ pressure is what a hammer relies on. Your hammer doesn't run to stall, it runs.[/QUOTE
Ohhhh. Understand what you are saying. So that isn’t a legitimate test.
That’s what I had, but got tired of the mess, I guess I’ll just have to put up with it.That is good news, we use straight JIC hose and fittings for the option. It's messy, but it works.
The relief is supposed to be 3190I just looked at the most common hammers I deal with and they spec the relief setting to be 65 bar higher than operating pressure.
Again I'd look at what the hammer manufacturer says to set the relief to but personally I think your relief is set a tad low.
The PSI to Bar conversion got lost in translation somewhere between my ears. Never mind, If it hits ok now you're good to go.The relief is supposed to be 3190
