willie59
OK if I understand this correctly a hyd cylinder can drift one way (rod going out) but not the other (rod going in) if the cylinder ports are blocked?
Which means that in order to establish if a piston seal is bad, you need to pull on the rod and block off the cylinder ports?
The reason I ask (apart from curiosity) is that the backfill blade on my Kubota KX91-3 drops at a fairly quick rate (it takes 20-30minutes to fully drop), now if I where to raise the machine with the blade then it should not drop unless there is a problem with the control/relief valve?
BTW do tipper hydraulic rams work by filling the sections with oil?
Your backfill blade dropping is pulling the cylinder out. Fairly easy to test if it's a piston seal problem Hendrik. Raise your backfill blade fully, then stick your digging bucket under it to hold it up. Disconnect the hose connections to the blade cylinder and block the ports with appropriate plugs/caps. Pull your digging bucket out from under the blade and monitor the blades movement. If it drifts down, got bad piston seal.
Not sure what your asking about the tipper rams.
