Toyota 7FGU30 No crank/No start please help
WaelB
Bakersfield, CA
Simon, I’m still trying to get a correct schematic but I just had a quick question for you. Is it possible that the grounds for some of these relays is actually sent through an ECU?
Simon C
Heavy Equipment Mechanic
I recall seeing the grounds going to frame only, or strap. Sometimes it is the flat braided style, sometimes it is welding cable style.
Simon C
WaelB
Bakersfield, CA
Yeah there are a couple big grounds going to frame. They are all good. Just no ground to the starter, ignition, and LPG relay coils. I tapped in a ground to the LPG relay and Ignition relays. Didn’t have to worry about the starter because it looks like the starter and Ignition relay share a ground. It’s working. Starts and runs normally but someday I would like to get to the source of the issue and understand what it was that has been giving me this huge headache
