Thoughts on a failed bucket cylinder
pados1002
Greece
Hey guys I 'm posting a couple of photos of a bucket cylinder that was repaired about 3 months ago from a machine shop. Rod was ok and only the tube was replaced and welded on the old ends. Yesterday the weld broke in half. I 'd like your opinions on this failure. Is it a bad repair or something else that I should probably look for on my hydraulics?
pados1002
Greece
Fortunately the shop is really helpful and immediately asked me to send the cylinder back to them. However they told me that a potential hydraulic malfunction when you go from opening the bucket to closing, if the the return oils don't work properly could cause such an issue. I ll try to check if this behavior occurs but I m not convinced.
