The JLG 40F Boom Lift Dilemma
OFF
Alberta, Canada
HD Mechanic
Was that recommendation for the oil/diesel mix in the Bertea manual? We used to mix 50/50 Kerosene and ISO22 hydraulic oil (I couldn't think of ISO yesterday) in the winter, but that was before synthetic oils were invented. Never had a pump fail, but it was always a risk. Modern oils are much better.
The hydraulic filter was the same for all the F series JLG's. The 80F had two of them stacked. I had a couple left, but I think I finally threw them away somewhere at the start of 2025. That part number you posted doesn't sound right. I looked it up, the tank filter is a number 2120055
OFF
Alberta, Canada
HD Mechanic
The high pressure filter canister weighs about as much as a large dog, and is very tight. Like a 48" pipe wrench with a 6ft snipe on the end kinda tight. No fun at all. But I believe Bertea systems also had smaller inline filters between the pump and the valve bank. Have a look.
maple2
vermont
Thank you Off and willie59 for the great information. I found the small high pressure filter, it is identical to the one pictured on page 21 of this thread. It's about the size of a coffee cup. Put a pipe wrench on it today that thing did not move a hair. I was hesitant to turn it more, did not want it to break. Is this filter under pressure maybe? Looks like maybe a bleeder screw on top of this filter. Maybe crack that a little let some pressure off? I looked everywhere for the high pressure canister filter that weighs as much as a large dog! Could not find anything like that. What area would that be located?
Knoxville TN
Service Manager
I'm going way out on a limb of memory here, but there's something telling me there's a fine mesh screen within the Bertea servo where the pilot oil enters the servo to prevent debris from getting in that area, have to take it apart to find it. But I could be wrong, been too many years. And years ago I've worked on old Skyworker bucket trucks from back in the 70's, the bucket control didn't use pilot pressure oil from the pump to operate, like most bucket truck controls do, nope, the controls on those things were their own independent hydraulic system. Had a small reservoir of oil at the bucket controls. Once you got all the lines bled of air, when you work the actuator at the bucket, each function acted like a master cylinder that would send oil down the boom lines to the valves at the lower. I recall on those machines you had to use ISO 22 cut 50/50 with Kerosene. If you didn't the oil was too thick to work the controls.
OFF
Alberta, Canada
HD Mechanic
That picture on page 21 of this thread, circled as #4, is a newer version of the old type high pressure filter I was thinking of. The old version is huge. In the 40F parts manual, page 2-57 figure 5 shows the big old beast.
Page #2-65, figure 2-36, item 67 is the inline filter used in the Bertea systems.
wiseman9986
Il
I just joined the club I purchased a 75? 40fn last night. Im not sure what is all wrong with it yet I need to get an alternator belt and it is leaking inside of the boom. What hydraulic fluid should i run? Im pretty sure if have the bertea valves.
wiseman9986
Il
Ill try to post some pictures once i have enough posts I looked through most of this thread yesterday and I didn't see any 40fn im guessing the n is narrow
OFF
Alberta, Canada
HD Mechanic
Welcome! Yes, N is for narrow and you have Bertea valves and controllers. And I see it's been converted to propane. Everything working or unknown at this point?
wiseman9986
Il
What i was told was that everything was working then about a year or so ago when they tried to move it only forward or reverse worked. Well I loaded it and looked at it in the middle of a rainstorm. They installed a new battery it starts and runs but the alternator belt was missing and kept losing voltage so nothing was working great. But once it was drove and winched up the trailer it did drive both directions. But fluid coming out of the boom had to hold the boom in with a come-along. Hopefully i can get a belt for the alternator and find the leak next week
Hopefully its just a hose i will probably be replacing all of them anyway but if its a cylinder i can handle that also.
  • Like
Reactions: OFF
wiseman9986
Il
Ok i got it looked at a little bit functions are strange it always wants to boom up but the up and down controls mostly dont work from the basket. I can control up and down from the back but its still always trying to go up i had to hold down most of the time. Telescope works but pours fluid out of the boom when i retract looks like that cylinder is going to be the first project. All of the toggle switches are kinda touchy i think I will just replace them all. Steering does not move at all i can hear something happen but they dont try to move ive tried with the black knob in and out. Im sure i need hydraulic fluid haven't decided what to use
OFF
Alberta, Canada
HD Mechanic
That black knob you mentioned is to put the steering into "tow mode" which allows the steering to free-wheel or follow while being towed. It could also have seized king-pins if the 40F has been sitting a long time. Put it up on jack stands, disconnect the steering ram and see you can get movement, either in the wheels or the ram.
On your proportional valve bank, each valve has a knob on each end. Make sure those knobs are out all the way. Each function can be operated manually on ground by screwing in those knobs.
Try and get a good strong lamp up your boom to see where the oil is coming from. It could be just a hose or broken fitting.
And Oil! ISO 22 hydraulic oil is the thickest you can go. See the top of this page where it is discussed.
ISO15 would be better for Bertea systems. ATF works also.
wiseman9986
Il
I do have the steering working alot of the time now couldn't tell you what i did lots of the problems are due to low fluid I belive I will see if i can find some buckets tomorrow. I had to turn the lift knob in so it would stop trying to go up all the time if im in the basket down doesn't seem to work and if im at the rear controls I just have to hold down all the time.
To me it doesn't look like there are Any hoses in the boom to leak they all go through the power track. I can tell its not coming from the basket hoses. And I can see where the hoses hook onto the block on the back of the hydraulic cylinder that is all dry.
Knoxville TN
Service Manager
The only hoses that connect to the telescope cylinder are the two hoses that connect to the manifold at the rear/base of the cylinder. The oil feed for the rod side of the cylinder is a piece of welded steel tubing inside the boom, not a hose. If you have major leaking while retracting the boom you most likely have failed rod seal in the gland of the cylinder, which requires break down.
wiseman9986
Il
The previous owner told me they used the farm and fleet brand john deere tractor hydraulic fluid which I think is more like 10w30 should i just plan on replacing all the fluid with iso 15? Do you know how much fluid it will use i read the resivoir is 40 gallons maybe I should just buy a 55g drum that's going to cost near what i paid for the lift
Knoxville TN
Service Manager
Universal tractor/trans fluid, including Hy-Guard and Hy-Trans are at least ISO32, which is equivalent to SAE 15W. Bertea valves don't perform well with that viscosity grade fluid.
OFF
Alberta, Canada
HD Mechanic
I've seen a telescope cylinder split from end to end. It was on an 80F. We dragged it inside a warm shop at -40, left it for the weekend to work on Monday.
I guess because of the lock valve, the oil couldn't escape and release pressure as things warmed up & expanded. JLG had no explanation for it.
