Takeuchi tb228 hydraulic leak. Does this unscrew I’ve circled in the picture?
BAMABOY
I have a Takeuchi TB228 that has just started leaking hydraulic fluid. I have found the location of the leak but not sure what could be leaking in this spot? I assume there’s maybe an O rings inside what I guess is called a valve body? Anyone familiar with how these work? In the picture I have taken off the fitting and was wondering if the area I have circled unscrews? Thanks
I think some better cleaning would be in order, before determining exact leak location.
A dye test will help but a big part of fixing a hydraulic leak, is determining exactly where it’s coming from.
Many mistakes have been made by many people over the years of where a hydraulic leak is, myself included.
Yes there should be an o-ring under that valve and it’s probably threaded with a boss type o-ring.
BAMABOY
Thanks for your replies. I unscrewed it without any problems. It only had one o ring and unfortunately it looks to be in good shape and not cracked or deformed at all. I was hoping I would find a bad o ring in this location. So now this tells me it’s the part underneath this piece. I have no idea what it’s called but it has 2 small Allen head bolts holding it on. The piece I removed was hollow and one o ring past the threads. In this picture I removed 14 from 5 and 5 is the part I unscrewed with the o ring on it. I’m adding a link to a video showing the leak maybe you can open it and see what it looks like. Thanks for the help
Click here for video
That’s one hell of a leak! It looks to be underneath that valve.
It looks like it may be coming from the spool cap.
There will be 2 Allen cap screws holding that cap on and it does have a recessed o-ring underneath that cap.
It could be a cracked cap or loose or a bad o-ring.
BAMABOY
So I can just remove the 2 Allen heads and the part will come off nothing else to do? Also are these o rings just regular type or they specific?
