notmee54
What are the most common electrical problems that would cause engine to shutdown and multiple warning lights.
Will run fine with no warning lights, until you turn it off when you try starting it again. Then it will run from 1-30 seconds and warning lights come on and it shuts down
Sometimes it's the rabbit air filter and (im assuming) engine rotation light.
Try it the next day and does the same thing runs good with no warning lights until you shut it down and start it again.
Sometimes it's the triangle and battery light.
I have oil pressure, and ALL the filters have been changed. New alternator, cleaned all terminals from alternator to relay box and all the terminals inside the switch/relay box... battery tested good about 12.9v and running tests about 14.2v.
Really getting frustrated...
Any suggestions on where and what to test would be appreciated.
