I recently picked up a tb145 to use on my property. I’m going through it now and fixing up leaks ect My 1st question is about leaking pilot controls … I called to get price on rebuild kit and was told $100 per side. I found it online cheaper . The kits is just some o-rings. Should I replace the pushers or anything other parts? Is there an expanded diagram of the pilot controls ? Any tips tricks ect ? Also looking to add a hydraulic thumb but my arm doesn’t have the top mount for the hydraulic cylinder … any thumb brands you guys recommend? Also directions on setting pressure to the aux hydraulics? I have seen several tb145s with broken arms due to improper welding for thumb or too high pressure to the thumb . Lastly can anyone post a picture of your battery compartment area ? I want to see how the electric fuel pump and water separator ect are mounted in that area . I’m sure I’ll have more questions as I go through the machine . Thanks !
