proplan2
Hi guys, I appreciate any help with my Takeuchi. The battery is not charging. I have already done to alternator replacement, but still no charge while the engine is running.
Specs: Takeuchi TB016 year 2005 with Yanmar 3TNE68 engine.
Alternator is the "dynamo type" (the slim one)
According to the workshop manual should make about 25V AC directly measured on the alternator, while engine is runnig - it does.
But on the dashboard still blinking the charging light and if I measure the battery, still the same voltage while engine is running or not (about 12V DC).
I know, that somewhere should be a regulator, but no luck to find it. Does anybody knows the location of the regulator? Or some other ideas, what should make this problem with no charging?
Thanks for any answer
PS: Images with the alternator type and the main relays in the battery area etc. attached.
