remus
Hello,
The following problem occurs with a VOLVO L120E model front loader:
when turning the steering wheel to the left, the wheels do not turn.
The steering wheel turns very easily, and there is a noise as if it has no hydraulic oil.
It happens less often when making a right turn.
I mention that the charger worked today for about 5 hours, after which the malfunction appeared.
I replaced the valve on the return hose (pos. 31 on the drawing), code VOLVO 11148129 (11172800), believing that the oil does not reach the steering valve in sufficient quantity.
The pressure measured on the steering valve is 100 bars and it drops to 0 and increases to 200 bars when I turn the steering wheel, to the left or to the right
Thanks in advance to those who will offer suggestions regarding this defect.
