Some oddball questions
RobVG
Seattle WA
17 excavators and a stewpot of other stuff
Measuring the depth of grease when checking swing pinion and ring gear? Nobody? Bueller? Bueller.....
Lee-online
In a van, down by the river
Improper lubrication can cause damage to machine components.
To avoid damage, make sure that the proper amount of grease is applied to the swing drive.
When the amount of grease in the compartment becomes too large, the agitation loss becomes large, thereby accelerating grease deterioration.
Grease deterioration can cause damage to the pinion gear of the swing drive and swing internal gear.
Not enough grease will result in poor gear lubrication.
Effinay
Pelham, NH
Getting organized with my own small business
I still haven't figured out how to grease the swing gear according to manufacturers recommendation. Supposed to be turning the house slowly as someone pumps grease from the outside. How in the he-double hockey sticks am I going to do that sittin' in the cab moving the lever?
RobVG
Seattle WA
Remove the diamond shaped cover between the boom cylinders. You should really follow the warnings in your manual but I just stand outside the cab and pull the swing lever carefully towards me at low idle. Flip the lockout lever back to lock each time you go to grease.
Put on a nitrile glove and squirt a golfball size lump of grease on your fingers. Stick fingers through hole and spread on as many teeth on the ring gear you can reach- usually 3. Start at the bottom of the gear and pull the grease up towards you. I grease about every 20 degrees.
Open gear grease like Texclad 2 or HighGear 20/20 comes in caulking tubes which are alot less messy than squeezing grease straight from a tube.
John C.
I unscrew the bottom of the grease gun out and pull out the plunger. Then you pull both ends off the grease tube and and use the plunger from the grease gun to push the grease into the tub. Do one tube at the quarter turn of the house if just topping off grease. If replacing the grease you use about ten tubes or more. Season to taste.
The other thing you can to is drill a hole for a grease fitting on the cover plate. Hook your battery gun on the fitting and tie down the trigger. Then rotate to your heart's content. What is recommended is thick grease and when these things come from Japan, the grease is about the consistency of a frozen cow pie. I like my grease just a little thinner as it is covered in the tub and just oozes around the teeth.
Think about that next time you watch some porn!
King of Obsolete
KINGDOM lynn lake manitoba
marketing my life style
oarwhat -- they went to a new server thing and my computer program to update the website is "obsolete". might have my new computer back before xmas with the new program installed.
thansk
KoO
Published Author
curb guy
central ohio
I would like to know how's the best way to clean the old,nasty grease out.The holes are about the diameter of a beer can.Needless to say,I cannot get my hand in there so,I rigged up a 'scoop' like thing.Geta the bulk out, but a real pain and takes forever.Is there a better way?
John C.
You crawl under the machine and look up in the carbody for another cover that looks similar to the one on the top on the house. Pick the machine up so that cover is on the low side and then remove it. Put some block under the tracks to hold the machine up for a day or so. You will find most of it will drain out making a real big mess of the inside of the carbody. Throw a pan under there when you are done and most will drip into the pan. Move the machine when you are done draining and put the cover back up. Fill the tub again and off you go. Good for another five years.
RobVG
Seattle WA
Question # 2
Replaced the intake manifold on my S10. Torque spec was 11 ft lbs. Didn't trust my old beam wrench so I bought a digital.
I torqued it in three steps. After the final one I decided to go around one more time. and found some that were about 2lbs loose. Two more times around and everything was good.
I didn't expect to have to re-torque them. Just wondering what would cause that?
mitch504
Andrews SC
Well now Rob, this is a simple one. The manifold deformed as the bolts were tightened, and 11 ft/lbs isn't enough clamping force to pull it down all at once. It just keeps pulling down a little every time until the surfaces are hard together.
Now, this is what I don't understand:
Do you really think an S-10 is worth torquing the manifold in 3 steps, much less buying a new wrench?
willie59
Knoxville TN
Service Manager
11 ft lbs ain't much pressure. Maybe it's just me, but I've been working with bolts and fasteners for so many years, with torque value like that, my hands would be my torque wrench. I do use a torque wrench on stuff like head bolts, main bearing caps, and connecting rod bolts. But stuff like that, I let my hands feel when it's there. ;)
Impact
Kentucky
Owner
My wife has been acting odd lately. She's been going to the gym every Wednesday. She stays out later and later every week. The last few weeks she hasn't gotten home till after midnight. She supposedly has been riding to the gym with her girlfriend. The last couple of weeks, her girlfriend has dropped her off around the block and she walks the rest of the way home. Then she started really guarding her cell phone. Half the time she doesn't take the call, simply turns the ringer off. I was going to move her phone from the charger the other day, and she came running over and grabbed her phone from me, not letting me look at it. Last Wednesday night, I decided to wait up and try and find out WHY she was getting dropped off around the corner, or WHO was actually bring her home. So, I rolled my Harley out beside the driveway next to the shrubs. I crouched down behind the Harley to hide, and that's when I saw it! The rear head gasket was leaking oil!
My question is this. Do you think I could fix it myself or should I take it to the dealer to be fixed?
RobVG
Seattle WA
Well Mitch, It's been a good truck. Yesterday it pulled an F150 out of a ditch. If it had been a Dodge I would have left it there.
gusbratz
PA
I wouldn't bother, it's a Harley. If it's not leaking oil from somewhere it means it doesn’t have any in it. By the way did you guys hear Harley has applied for a patent? They have actually devolved a new process that turns fuel directly into noise without the side affect of power.
JGS Parts
Australia/China
Owner JGS Machinery
hahah love it mate
mitch504
Andrews SC
Hey Impact,
I kinda scanned your post and got all excited, I thought you had found a dealer who could fix wives!
