Hey there, I’m at my wits end trying to figure out an electrical issue on a kobelco 135 excavator. It’s a SRLC, approx year 2000, serial number YH01-. I’m really hoping someone out there might have some insight. It’s got about 7k hours and we just bought it to work on the farm. The machine is tight for its age and has clearly been pretty well greased and maintained over the years. Got it home, changed all the fluids, filters, repacked all the cylinders, and gave the machine a good wash. Haven’t used it yet on any projects because it has developed an intermittent electrical issue. I only ran it twice before I noticed the issue but the issue did appear after I pressure washed the machine. It’s unclear if this is coincidental or not. The cab wasn’t pressure washed, and no water has been anywhere near the CPU. When the issue is present the screen shows a #1 CPU failure code for the mechatronic controller. I have the original kobelco factory service manual. I can’t run the computer diagnostic test because the CPU is just reading failure, it won’t let you get to the diagnostic screen. The strange part is this issue is intermittent. If you start the machine for the first time in 24-48 hrs the machine will fire right up. It will run completely fine, no codes on the screen. Then when you shut it off, if you immediately turn it back on it will say that mechatronic failure code and the machine will stay at idle. The computer doesn’t activate the stepper motor to rev the motor up. All the functions work but they are extremely weak since the machine won’t rev up. The knob to adjust throttle does nothing because the computer is not engaging the stepper attached to the injection pump. When you turn the key off the motor continues running because no signal is being sent to the stepper to shut off the injection pump. But again if you let it set for 24-48 hrs and then restart it, it functions exactly the way it should until you turn it off and back on and then the problem comes back up. I read all of the information the service manual had to offer. I’m pretty competent with electronics and have worked on all sorts of machines over the years. I tested all the input pins for power and all the grounds, even load tested the power inputs. All of that checked out. I took the panel off the front of the mechatronic controller and tested the pins inside to see what the outputs were. Most of them are in their specified range. Although some are reading outside their ranges. With some pins that had output specifications as: GND/Open but they were reading 14v? My thought was the CPU is bad but the fact this problem is intermittent is very strange. It returns completely to normal and operates fine in between episodes. I’ve been chasing harnesses looking for shorts and bad grounds and can not find anything that makes sense of the issue. With it being intermittent I was convinced the pressure washing got water in a connector or something like that and caused a short. At this point I’m not so sure. My local dealer told me they had this issue before with the same machines years ago, and he said it was always either a bad CPU or inadequate voltage supplied to the CPU that would cause it to throw that code. However the intermittent nature of the problem was strange to the dealer, he didn’t have a good explanation for that. I can post pictures of the service manual and the readings I’m getting from different pins on the CPU if that is helpful. My local dealer has a CPU for the machine for 2500$ but I really don’t want to throw money at the problem if I’m not sure this is the source of the issues. Any help would be greatly appreciated
