T_Gunn
I just pulled the valve covers off the engine on my Link-belt LS2700. All of the original gaskets and rubber grommets were heat hardened and brittle. There was oil leaking all over the engine and has been for a long time. It looks like the previous owner tried taking it apart and resealing everything with gasket maker. It didn't work. I can't understand why someone wouldn't just spend $100 on a gasket set and fix the problem the right way! Anyway, I was thinking I might set the valves while I've got the covers off. I will get the clearances from the local engine dealer. It has been at least 10 years since I've adjusted a set of valves. Does anyone have words of wisdom? How do I turn the engine over to get the rockers in position for adjustment? Am I crazy to be doing this on my own?
