Bleeding Steering Case? D21P-5 .. Hyd Filter info
Bleeding Steering Case? D21P-5 Left brake cover was removed to refurbish the brake crank shaft and add lube point. Now it seems that the left steering clutch is not disengaging the clutch 100% .. it will turn left with added effort and lugs down the engine a bit, and the right side works fine as before. I'm wondering if there is a method to perhaps bleed the left steering clutch piston system? I'm thinking perhaps there may be some air captivated within, reducing the piston travel.
The mini-pipe plugs on mine are 9/32" square male, and given that this machine is 30 years old, I have opted to get the right tool .. I don't have a 9/32" 8-point socket
Grey Pneumatic (1211P) 3/8" Drive 11-Piece Pipe Plug Socket Set (Amazon) .. the 9/32" female socket fits Perfectly. Now the machine Is Functional, but if I can restore the left clutch to proper disengagement that would be awesome. I have already adjusted the lever to plunger to minimum spec (0.5mm to 0.0mm clearance). I've got two bladder tank pads to excavate here (20k & 50K) .. Cali drought stuff.
Filter cross reference hell. Now I swear by Wix filters .. and Delo 400 .. my D21P-5 has over 28K hours on her. The Wix cross for the D21P-5 hydraulic filter is A24A10E which crosses over to a NAPA version available for the paltry sum of $160 .. totally ridiculous. I did find another vendor online selling it for $70 .. still pretty darn pricey. I checked the threads and they are 48mm x 2mm .. humongous for a small dozer, but it is what it am. What I found is .. Fleetgaurd HF7935 .. fits perfectly. Found one on evilbay for $16 shipped .. sweet! Still in the shrink wrap stuff .. says Made in Italy .. go figure
Apparently common to large Volvo and Hitachi excavators requiring high throughput. Online it also crosses over to Baldwin BF8906, Donaldson P502382, and lastly Luber-Finer LFH5941. Luber-Finer was bought by Fram, so caveate emptor. Hope this helps you guys .. spend your saved money on something less boring ehh
Vendor recommendation: Placed a $370 bulk filter order (8 machines, 2 generators, and 2 vehicles) from these guys down in Texas, and you might give them a look. As you know Napa Gold is Wix, and I got a mix of Wix and Napa Gold in my order, and probably saved close to $150 over what the local prices are here for Wix. Fleetfilter dot com. Cheers!
