mitch504
Link worked great, thanks very much.
Mitch
Mitch
the front one is for the transmission, SAE30w motor oil, the one at the rear is the bevel gear, SAE30w motor oil, the plugs on the rear case, the final drives, SAE30w motor oil, you will find a plug on the inside bottom of each final drive, this is the drain plugs, the hydraulic system takes either SAE10w, SAE10w-30 or SAE15w-40 your choice on these, these machines use automotive motor oil for everything, hope this helps.
Would it be ok to change the cranckcase oil, etc. by using a vacuum suction pump down the filler tubes so as not to have to crawl under the dozer?
I'm new here and not sure if this where im supposed to post? I have a question hopefully someone can help me out. I recently bought a d20a and it's been sitting a long time. When I try to steer right it lugs the engine down but won't stop the track from turning. I think that the brake is working like it should but the right clutches are stuck causing it to choke the engine down. If this is my problem then what do I need to take apart to check? Thanks for any help.
